RPM limiter
RPM limiter
Last time I ran the 1/4 mile I tried finishing in third gear, however right before I crossed the line I was at about 6000 rpms, my car stoped taking fuel and made the same jerking that it makes when I hit my speed limiter, which is at 118 mph.
Anyway, how high does a stock LS1 goes into the rpm range is it 6000rpm. And I am getting a bigger cam within the next month, which will probably peak at around 6600rpms, so do you have to buy a programmer to change this limit or get it tuned, which I plan on doing.
Re: RPM limiter
Originally Posted by shouldaboughtthez
speed limit 118? I have had mine faster than that.
Re: RPM limiter
When you get your PCM tuned for the cam, you'll need that 6200 rev limiter raised a little
, and have them get rid of the 118 mph limiter while they're at it
Just so you know, the factory tachs don't always read 100% accurate.....it may look like only 6000 RPM, but in fact the limiter doesn't kick in until 6200 RPM
.Just so you know, the factory tachs don't always read 100% accurate.....it may look like only 6000 RPM, but in fact the limiter doesn't kick in until 6200 RPM
Re: RPM limiter
And also with raising the rpm limit, the engine won't have any problem running as high as 6600 rpms? I'm also going to do Dual Springs, Titanium Retainers, Seats, Intake/Exhaust Valve Stem Seals, & Hardened Pushrods with the cam.
Re: RPM limiter
Originally Posted by Schmidt519
Yea, I wasn't sure exactly where the limiter was on the rpms, I just knew it was around 6000rpms. I've only hit the rpm limit once, when I tried pushing it to the max at the track.
Re: RPM limiter
Yea, I think my Z came from the factory with 6 cylinder tires, which is why I have it at 118, it all depends on which kind of tires they put on it, or so I've been told.
techstar
Aug 6, 2015 11:20 AM
zajones
Jul 30, 2015 02:18 PM
Jul 17, 2015 02:47 PM
