Rocker adjustment
Old Jul 29, 2003 | 12:16 AM
Low68's Avatar
Question Rocker adjustment
Hello, I just joined to ask a question. I don't have a camaro, but I would really appreciate any help you could give me. I have a 68 chevy truck with a fuel injected gm crate engine. I put on some gm fast burn heads and the hot cam. My question is about adjusting the roller rocker arms. I did a search to look for the question and I found a thread that sounded exactly like the problem that I am having, but I had some more questions. The thread I found was here http://web.camaross.com/forums/showt...ng+rocker+arms . I had the same thing happen to me while I was adjusting the rocker arms. I would adjust the rocker to zero lash and tighten it half a turn. Then I could push down the front of the rocker and rotate the back off of the valve spring. Is that normal? The lifters aren't new, though they have been sitting out of the engine for a while. The engine is not in my truck right now so I can't start it up to test things. I was hoping to adjust them before putting it in the truck. Will I have to run it and adjust it again. Thanks for any help you can give me.
Old Jul 29, 2003 | 06:07 PM
Low68's Avatar
Anyone?
Old Jul 29, 2003 | 06:10 PM
chpmnsws6's Avatar
you could try posting it in the other places on this site where some of the older cars are that might have the engine your talking about
BTW- welcome ot the boards!!!!!!! don't stay on long or you will be looking for an ls1, i know i did and now i need my name changed
RUENUF
Mar 13, 2016 03:37 PM
Quickss96
Jan 29, 2016 05:56 PM
Slayer
Aug 17, 2015 03:55 PM
realistyc
Jul 28, 2015 07:32 PM
JCSWS6
Jul 19, 2015 06:47 PM
