CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   right direction? (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/right-direction-339280/)
myslowcamaro Feb 7, 2005 02:48 PM
right direction?
im new to the forum but had my z28 2 years now just never threw any major money into it. lately ive been buying parts to be thrown in all at once to cut costs. before i finalize my shopping list, i just wanted your 2 cents on: have my stock heads ported or just buy stage two heads? local shops want $1200+ to port three angle valve job.
i buying mac headers with orp, and simms, do i need the extensions?
im also looking for the ssra, roller rockers and a bigger cam which im still researching, maybe t-rex? custom exhaust from the orp back with a flow master muffler, keeping my e-cutout. anything wrong or mismatched with the above combo before i empty my pocket?
rwb Feb 7, 2005 02:58 PM
Re: right direction?
If you can swing it get the AFR heads or some from a reputable shop or vendor.
6speedZ28 Feb 7, 2005 02:59 PM
Not so sure you would wanna go with a T-Rex cam being an automatic car and all. I have heard that the cam is almost to big to be streetable. Ask around about it.
myslowcamaro Feb 7, 2005 03:16 PM
afr heads?
Demon SS Feb 7, 2005 03:24 PM
Originally Posted by myslowcamaro
afr heads?
AFR heads are a true aftermarket head developed and produced by AFR, they are not a stock LS1 ported and polished head. Very good heads, just a bit pricey for some at about $2200.00 shipped.
Lots of options for cylinder heads- FFHP for example :D
The T-Rex cam will not work with aftermarket heads without flycutting the pistons and is considered by some to be not a good daily driver cam as it is quite thumppy. It is all a matter of preference.
