This really sucks....
Just finished my cam install after I had to replace my valves. My car was running like *** cuz i had bent valves. So now with new valves, pushrods, springs, retainers and a new cam, my car still has a blinking SES light and I have no idea why...crappy thing is now I have to go pay $45 for a mechanic to hook up a real scanner and tell me which cylinders are misfiring and how bad. Hopefully its not as bad as before my valve change...he tested it and 5100 was my worst misfire.
The car runs nowhere near as bad as it did before I changed all this stuff, but the engine still vibrates a good bit. The car doesnt really stumble or anything either. Could it be a coil or a pulg wire?
Originally posted by 99blackSS
Autozone will scan your computer for free. I figured that out shortly after paying $75 just to find out my headers were setting the SES light.
Originally posted by Demon SS
how big is the cam?
the blinking SES light is due to a random misfire(probably)
check your plugs and wires also.
how big is the cam?
Originally posted by bombd84
so how does it run now? Man dont you feel lucky it was just your own fault. I know I do when its small dumb stuff like that.
Who tuned the car after the cam? I take it you mis-shifted 2-1 or 3-2 right; that is how you bent your valves? You should have just got a set of heads from Patriot instead of rebuilding your existing stock ones.
