Quieting Down the Pro 5.0
I installed the Pro 5.0 using a gasket between the base of the shifter and the car as suggested by the install on projecttransam.com. I also just put in the rob mod.
It's still loud!!
Does it quiet down with time? (Maybe the parts have to settle together)
Does anyone have any suggestions? I've heard of using two boots or putting dynamat on the stick. I believe that the dynamat would its way down the stick that way.
It's still loud!!
I know you dont want to hear this but turn down the radio.You can apply all the silicone you want but it wont be quiet.
2001 Camaro SS M6
11.901@115.82 1.71 60 ft.
342 hp 355 ft/lbs
Boltons running on DR's
1990 Eclipse GSX M5 stock for now
2001 Camaro SS M6
342 hp 355 ft/lbs
