CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   Question About Odometer? (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/question-about-odometer-114527/)
JG11 Apr 30, 2003 05:45 PM
JUst a quick question. Is there any way for the dealer to tell how many original miles are on the car if I disconnect the odometer, or take the guages fuse out? Just wondering because I was thinking about doing this...
Eric L Apr 30, 2003 06:13 PM
odometer fraud is highly illegal.
stik6shift98 Apr 30, 2003 06:23 PM
no.........
as long as you dont go to a place where they register miles like change the oil emiisions and stuff like that u will be ok
and yes its very illegal
crazyswede1027 Apr 30, 2003 07:33 PM
so you want to drive the hell out of your car for a long while, but not record the mileage so that three or four years down the road you can sell a supposed low mileage car. Great idea. That is sarcastic if you can't figure it out. What possible reason would you have for disconnecting the odometer other than to defraud someone. Just hope someday you aren't on the losing end of that one.
SpecForceZ28 Apr 30, 2003 09:09 PM
Odometer fraud can be turned into a felony really quick
stik6shift98 Apr 30, 2003 09:25 PM
let him do it if he wants to........not our problem
SFB767 Apr 30, 2003 10:19 PM
Re: Question About Odometer?
Your best bet would be to go to your local police dept. to ask them how to do it, seriously.
stik6shift98 Apr 30, 2003 10:32 PM
Re: Re: Question About Odometer?
lmao
99blackSS Apr 30, 2003 10:35 PM
All you have to do is take out the fuse that goes to the cluster? I thought it was harder. Besides you can't really get away with taking off very many miles.
stik6shift98 Apr 30, 2003 10:48 PM
wneh u pull the fuse the whole cluster doesnt work.....
and why couldnt u get away with a lot of miles......u could always buy another cluster for under 100 bucks and run your miles up on that for awhile
Jason Novak May 1, 2003 10:50 AM
I read somewhere that is also stores your mileage in the PCM, too, so if someone checks they’ll know something is up since they won’t match.
Aklaim May 1, 2003 10:59 AM
This is true. The odometer is just the visual representation of what is stored in the PCM. Pull the fuses all you want, your milage is still being recorded. I know, I had a buddy try to defraud his VW dealer by doing the same thing. He's not too bright.
stik6shift98 May 1, 2003 04:00 PM
so what your saying is that if he pulls the fuse the mileage will still be registered and once he plugs the fuse back in it will record the miles he drove with the fuse out????????
.....if thts what your saying then you are wrong
Cbra Kilr May 1, 2003 04:34 PM
lol
dont you think the guys at gm already thought of guys like you trying to screw everyone else. IT is saved and they will know. Your pcm is always running, when something doesnt match up, they will know
stik6shift98 May 1, 2003 08:53 PM
Re: lol
are u sure????
i see people just post that cuz they heard it somewhere but does one of you actually know for sure.....i beleive that that isnt accurate
