QA1 + Eibach Prokit
Qa1 and Pro-kit springs on all four corners for a solid blend of strip and cornering, I know the springs dont help for the strip. other than that is it a good/bad setup?
how does it ride, look etc etc. ANY feedback is appreciated. Thanks in advance |
If your going to the strip alot then it would be a nice set up, but if your not going to go that often maybe 10-15 times a yr. then I would say go with some bilstiens and the pro-springs. They are great for an everyday driver too. You might want to think about it if your car is an every day driver. The hal's would be fine but they are really best used if you go to the track "alot".
