proper plug gap and larger oil filter #
what is the stock plug gap for the LS1?
i got the NGK tr55 plugs with .50 gap, seems i remember hearing the proper gap is .55
and i know there is a larger capacity oil filter that replaces the standard filter on the ls1...what is the number on that.
thanks
thanks
I'm about 99% sure the factory spark plug gap is .060. I'll check it and get back to ya.
Here are all the filter numbers from autozone's website. This is the filter used on the 6.0L 3/4ton pickups. It's what I use on my car and is about 1" to 1.5" longer than the stock LS1 filter. The bottom of the filter sits just even with the bottom of the oilpan.
STP S3675
BOSCH 3423
MOBIL M1-206
FRAM PH3675
AC-DELCO PF59
K&N HP-2006
STP S3675
BOSCH 3423
MOBIL M1-206
FRAM PH3675
AC-DELCO PF59
K&N HP-2006
I use the ACC Delco PF 59 (fhey changed the number, it used to be PF58) - the filter fits just fine. Acc. to the AutoZone oil filter list it's for a 91 Caprice (???).
I never used KN oil filters - don't know if they're worth the money. Some filter manufacturers claim that their filter catch smaller particles. Well, that's fine but may plug up the filter ....
sweet thanks guys...
plugs and wires tomorrow, slap the coil packs back on and fire that bitch up...
can't wait to hear the open LT headers!!!
will be doing a writeup on the flowtechs this weekend
Originally posted by mullettour
Yeah, I just checked a few sources and it is in fact .060.
NGK tr55s gapped at .050 work great in both of our LS1s.
