po 1416
Hiya Guys,
I have a po 1416 error, which i understand the most probable case is the passenger side air check vavle. The problem I am having is no one seems to know what an air check valve is. Is it a O2 sensor?. Are there any instructions on line for changing this? Is it easy to change? Thanks in advance |
It's not an 02 sensor. Do a search for "P1416" in LS1 Tech - there's a bunch of threads, you may get some instructions there. :)
| All times are GMT -5. The time now is 04:04 AM. |
