obd2 code 430
just acquired an obd2 code reader and came back with this 430 code that relates to camshaft positioner sensor ,car runs fine ,bought it used a year ago and was wondering if maybe the dealership had repaired it and didn't remove the code,
If the sensor was bad wouldn't I notice it in the performance end.seems to have great power,no missing ,knocking, etc. |
P0430 is a passenger side cat inefficiency code...
Originally Posted by 2001NBMZ28
(Post 5368738)
The code for the cps is P0336, and the cps has no effect on performance, its there for misfire detection. Most likely you need a new cat, but bad cats are usually a symptom of another underlying problem (running rich, coolant in the engine, etc). |
Looked at a couple of your posts, since you have an 02 and less than 120K the cat is covered under warranty.
obd2 code
thanks for info , does this site have a list of obd2 codes for 2002 camaros ? the reader I have came with a book of codes for what car I don't know. MAde in CHINA
Also I reset the 430 code and was wondering how long it should take for it to show up again if there is a problem?? |
Best place to look up code descriptions/diagnostics for 98+ is gearchatter.com
| All times are GMT -5. The time now is 09:26 AM. |
