Noise around Water Pump area
hey guys, ive been hearing some nasty squeeky noises comming out of my water pump's Pulley area, ive checked autozone and they have a pulley for around 40 bucks and btw does anyone have the part number for a water pump? or is there an upgrade i can do? thanks.
THey tend to squeal if the bearing is gone.. if you see leaks, it may be time for a WP.. You mind as well just replace it if the bearing is gone..
replace what: the pulley, the pump or both? and btw do u happend to have the Part No.?
You may end up just replacing the whole water pump.. if they're squealing, it's the only way..
I'll check for the PN... |
thx
