CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   New Air Intake Problems (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/new-air-intake-problems-516754/)
mbirler Apr 23, 2007 09:13 PM
I have a '98 Z28 with 145,000 miles and recently put in a new ram air/high flow air box system from SLP (better late than never I guess). The car is now hesitating and giving me a low voltage code (running lean) for all four oxygen sensors (codes are PO131, 137, 151, and 157). I was told that I needed to reset the PCM by disconnecting the battery and reconnecting it. I tried this, and I still have the hesitation. Anybody out there have any experience with this problem?
teke184 Apr 23, 2007 11:00 PM
bad maf sensor
try pulling the plug to the maf and see if it runs. if it does, it's most likely the maf.
had that happen on my car when i put a Z06 maf on it. pulled the plug and it ran fine...swapped the stocker back on and it ran like a champ.
worth a shot
