CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   LS6 Cam (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/ls6-cam-286577/)
Ls1smlblck Jul 28, 2004 09:10 AM
LS6 Cam
Is any one running the LS6 cam and what have been the results?
bombd84 Jul 28, 2004 09:41 AM
Re: LS6 Cam
A guy I know first hand dynoed 361/35X to the rear wheels in a 02 bolt-on car WITHout headers.
Ls1smlblck Jul 28, 2004 09:55 AM
Re: LS6 Cam
Do you know if he used the LS6 Springs and had it tuned?
teke184 Jul 28, 2004 10:57 AM
Re: LS6 Cam
you have to use bigger springs...the ls6 springs are the inexpensive choice.
ULTIMTEORANGESS Jul 28, 2004 04:58 PM
Re: LS6 Cam
i went with ls6 springs and had my car tuned.
i got this cam for its cost and streetability.itll make nowhere near the power down low like other cams but its good for what it is.
bombd84 Jul 29, 2004 06:23 PM
Re: LS6 Cam
He didnt have his tuned. I raced him and wasnt to impressed. The only gains that you will see are pretty much past 5500 rpms, therefore the only time it will really shine is when your doing high speed runs and are in your upper rpm ranges for an extended period of time. When we raced it was even untill we were about to shift then he would start to pull. Once we shifted it would be even again untill he reached the upper rpms. There are plenty of other cams out there that are just as streetable as the ls6 cam but will make substantially more power.
edit* we raced before my headers and true duals
LT-14me Jul 29, 2004 10:59 PM
Re: LS6 Cam
i too was concidering the LS6 cam because of its affordability, but then i realized that if i am gunna spend all that money on a cam swap it might as well be something thats gunna kick ass all over the place...i heard that the trex cams are good and the ls1 hotcams are good as well...but i have to pass the sniffer so we will see what the future holds
BirchMan98z Jul 30, 2004 05:03 AM
Re: LS6 Cam
any custom grind cam will make the ls-6 look weak.
