ls2
ls2
i got a 94 camaro v6 trying to change out but at this dealer ship they pulled out a ls2 dont know why but as long as it didnt crack the block i want it thats but im trying to get right now i was wondering though would it run like off the ls1 computer and will the ls1 tran hook up to it what is the different between the camaro ls1 and the gto trans i dont know what the gto trans is
What the hell are you talking about? What illiterate person wrote that paragraph for you? If your buying a motor and trans why wouldnt you have just bought an LS1 to begin with. Im still trying to figure out why pulling a motor out would crack the block.
It wont work anyway. LT and LS motors are meant to go with 6spds not 5spds. Nothing would line up, same goes for the driveshaft which would have to be made longer to work. This is the worst setup Ive seen. Just buy a V8 if thats what you want.
you do know that all driveshafts are interchangable between the 3rd gen and 4th gens...manual or auto...6cyl or 8cyl
but yeah...my head hurt after trying to read that paragraph
It wont matter 3rd or 4th because its the same frame, and it wont matter V6 or V8. I was under the impression that the 6spd trans is longer then the 5spd, therefore a driveshaft would have to be custom for such a swap to work.
hey snakeskinner umm i was saying if the block WAS CRACKED i dont want it but if its cracked and u want it let me know how about it. They pulled it out of a gto there is a chance that it could be cracked damn cause it locked up so they put another engine in it
You need to take advantage of that free tuition that is afforded to GA residents, although from the looks of things you might fall short on the placement tests. Your freshman schedule would most likely consist of lots of 00000001 classes. "but if its cracked and u want it let me know how about it"
WTF is does that mean. You have to be kidding right, i mean no one above a certain age can really be this stupid.
[QUOTE=psychocabbage;4459489]give him a break.. he spelled Camaro correctly in his screenname..
Yea but he probably had to run back and forth a few times to look at the back of his car to see how to spell it.
I see that you just joined, so welcome! Use the search feature that this kick *** forum has to offer. There are many posts asking about LS1/2 swaps into 93-97 Camaros, along with many other questions you may ask. And please, use a period once in awhile! It is hard as hell to read what you said. Well, at least you didn't write in all CAPS.....
[QUOTE=SnakeSkinner28;4459564]
I can see trying to correct him but your going a little overboard......
Just search for LS1 swaps and you will find what you need
Hotrods&Muscle
Feb 18, 2015 06:38 PM
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Hotrods&Muscle
Jan 18, 2015 08:08 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
