LS1 Wheelie
About how much crank or wheel horsepower does it take to do a wheelie? I mean the minimum amount in order to do what you'd consider a wheelie. Also, how long can the stock suspension take this for? Is there any way to beef it up to take the abuse?
------------------ 95 Silver Z28 Camaro Not bad for 16, eh? |
I've seen it be done with 350 rwhp, skinnies and very sticky tires/good track prep...in short HRP http://web.camaross.com/bb/biggrin.gif
Rick |
I don't know that you could do it on the stock suspension. You would most likely need to purchase a lot of aftermarket equipment to get the car to hook up well enough to pull a wheel.
------------------ - Steve - 1998 Pontiac Firebird Trans Am LS1 A4, 2.73's, Kumho Ecsta Supra 712 245/50/ZR16's, Direct Flow Lid, GMAF, !FRA, Loudmouth, 3" Y-Pipe, AIT Mod, Fan Switch Mod 13.774 @ 103.33, 300rwhp & 308.6rwtq, 97+ RPO Codes, Join The CamaroZ28.Com Users Webring |
<font face="Verdana, Arial" size="2">Originally posted by 96fbirdA4: I don't know that you could do it on the stock suspension. You would most likely need to purchase a lot of aftermarket equipment to get the car to hook up well enough to pull a wheel.</font> |
I lifted tires in 2000, with 375rwhp/408tq...
I lift them higher with 450rwhp/500tq. PICS: www.ls1tech.com/moderators/psj ------------------ 1998 Formula | ARE 422ci iron block with Stage II heads | 40 lb Injectors | LS6 Intake | TTS headers | 3" ORP | Mufflex 4" Catback | MSD Wires | Whisper lid | SLP MAF | FLP level IV 4L60E | Yank TPE4400 | Moser 9"/4.10's | RT Torque Arm | HAL Shocks and Springs (front) | V6 Springs (rear), Alston 8 pt Rollcage | Airlift Airbag | Weld Prostars | ASCD Hood | 11.15@120.30mph 1.53 3625 raceweight LS1TECH.COM |
The only suspension mods I have done to my car are a set of G2 LCA relocation brackets, an airbag in the right rear spring, and a set of Hal QA1 12-way adjustable Hal struts. My best 60' time is a 1.588, and you can click on my homepage posted in my sig to see the picture. http://web.camaross.com/bb/smile.gif This is with 361 RWHP. I am getting ready to upgrade with the G2 torque arm, lightweight control arms, and lightweight panhard rod. Another cam swap is in order, too. http://web.camaross.com/bb/biggrin.gif
Trevor - LGM ------------------ '02 SS: 11.63 @ 114.06 MPH, 1.588 60'; 3,515# raceweight, 1,102' D.A. naturally-aspirated with bolt-ons, a cam, and a fat converter! L.G. Motorsports (972) 272-7753 Check out the SS! |
Can you do this with a stock rear end? Can the stock rear end handle many of these launches?
------------------ Steve 2002 Trans Am WS-6 M6, Pewter |
<font face="Verdana, Arial" size="2">Originally posted by TireSmoke: Can you do this with a stock rear end? Can the stock rear end handle many of these launches?</font> To go out and start pulling wheelies, you'd need a lot of beefed up parts on your car, otherwise you're gonna start breaking $h!t left, right, and center. JMO. http://web.camaross.com/bb/wink.gif ------------------ 2002 Z28 - A4, 2.73's, Blk/blk, leather, T-tops, sport appearance package - just bought on June 26, 2002! - Pics 1981 Z28 - 383, TH350 trans., 3.42 posi - sold August, 2000 - Pics 1973 Camaro - Dad's & my project in the works - to be built: 355 Chevy, 11.5:1 pop-ups, "camel hump" heads (w/2.02 valves), solid cam, 4-speed.....it should be quick! - Pics |
All you have to do is put hydraulics on the front and right when you take off, it will lift the front. Then you get your wheelie.
He He. Im just messin. |
My 95 firebird would lift the front tires about 3" with totally stock suspension and 28x10.5W et streets. The guy I bought my car from did not believe in after market suspension.
| All times are GMT -5. The time now is 08:05 AM. |
