LS1 valve ajustment ???
Valves can't be adjusted. The stock valvetrain is non-adjustable. The head holds the spring seat, the valve seal, the spring, the retainer and then the lock. Mount up the rockers with the pushrods in place, torque 'em down, and that's it. You can use shims and different length pushrods to make adjustments to valvetrain geometry or have a machine shop do some custom work on the heads. But for stock components, that shouldn't be necessary.
He's probably referring to adjusting the rockers to get rid of that clattery "loose/sloppy rocker" noise?
You know the one that every LS1 has ever since they're brand new???
Welcome to the LS1!!
Great motors ... just a little too noisy from more places than just the exhaust?!!?
You know the one that every LS1 has ever since they're brand new??? Welcome to the LS1!!
I've had mine since BRAND NEW, and it's had those "tap/rattle/knock/clatter" noises since DAY ONE
. Now with over 105,000 km (~65k miles) and it still runs like a champ, I'm not too concerned about them any more
I'm not the one lacking power!!!
thanks for the info !! got any suggestions ???
hey guys ,thanks for the 411 ,, i didnt think they were ajustable. guess its roller cam noise .. but then again my cars got 106,000 miles on it two . but other than that it runs like a new one , doesnt burn any oil has good oil pressure . best et with drag radials 8.34 1/8 mile 97.4 mph , spining out the hole .
does anyone have some suguestions for my car ?? it already got the slp cold air kit , ported tb , polished maf ,free mods . 98 z28 m6 3.42 rear
