LS1 Assembly Torque Specs:
Hey guys: I know very little about the nitty gritty of the Gen III. I am helping a buddy reassemble his LS1. What do you torque the mains to?
Thanks. Rich |
Inner bolts and outer bolts first pass: 15 lb/ft
Inner bolts final pass: additional 80 degrees Outer bolts final pass: additional 53 degrees Side bolts (cannot be reused): 18 lb/ft |
Originally Posted by Marc 85Z28
(Post 5920327)
Inner bolts final pass: additional 80 degrees Outer bolts final pass: additional 53 degrees Side bolts (cannot be reused): 18 lb/ft Rich |
I need to write this **** down in a book somewhere so I don't have to search for it in the future... :lol:
Originally Posted by Chrome383Z
(Post 5920687)
Originally Posted by JakeRobb
(Post 5920720)
I'd rather search for it here than search for it in a book... :shrug:
Accelerator Control Cable Bracket Bolts 89 lb in Air Conditioning Compressor Bolts 37 lb ft Air Conditioning Compressor Bracket Bolts 37 lb ft Air Conditioning Idler Pulley Bolt 37 lb ft Air Conditioning Tensioner Bolt 18 lb ft Air Injection Reaction (AIR) Pipe-to-Exhaust Manifold Bolts 15 lb ft Camshaft Retainer Bolts 18 lb ft Camshaft Sensor Bolt 18 lb ft Camshaft Sprocket Bolts 26 lb ft Catalytic Converter Nut 18 lb ft Connecting Rod Bolts - First Design (First Pass) 15 lb ft Connecting Rod Bolts - First Design (Final Pass) 60 degrees Connecting Rod Bolts - Second Design (First Pass) 15 lb ft Connecting Rod Bolts - Second Design (Final Pass) 75 degrees Coolant Temperature Gauge Sensor 15 lb ft Crankshaft Balancer Bolt (Installation Pass-to Ensure the Balancer is Completely Installed) 240 lb ft Crankshaft Balancer Bolt (First Pass-Install a NEW Bolt After the Installation Pass and Tighten as Described in the First and Final Passes) 37 lb ft Crankshaft Balancer Bolt (Final Pass) 140 degrees Crankshaft Bearing Cap Bolts (Inner Bolts-First Pass in Sequence) 15 lb ft Crankshaft Bearing Cap Bolts (Inner Bolts-Final Pass in Sequence) 80 degrees Crankshaft Bearing Cap Side Bolts 18 lb ft Crankshaft Bearing Cap Studs (Outer Studs-First Pass in Sequence) 15 lb ft Crankshaft Bearing Cap Studs (Outer Studs-Final Pass in Sequence) 53 degrees Crankshaft Oil Deflector Nuts 18 lb ft Crankshaft Position Sensor Bolt 18 lb ft Cylinder Head Bolts (First Pass all M11 Bolts in Sequence) 22 lb ft Cylinder Head Bolts (Second Pass all M11 Bolts in Sequence) 90 degrees Cylinder Head Bolts (Final Pass all M11 Bolts in Sequence-Excluding the Medium Length Bolts at the Front and Rear of Each Cylinder Head) 90 degrees Cylinder Head Bolts (Final Pass M11 Medium Length Bolts at the Front and Rear of Each Cylinder Head in Sequence) 50 degrees Cylinder Head Bolts (M8 Inner Bolts in Sequence) 22 lb ft Cylinder Head Coolant Plug 15 lb ft Cylinder Head Core Hole Plug 15 lb ft Drive Belt Idler Pulley Bolt 37 lb ft Drive Belt Tensioner Bolts 37 lb ft Engine Block Coolant Drain Plugs 44 lb ft Engine Block Heater 30 lb ft Engine Block Oil Gallery Plugs 44 lb ft Engine Coolant Air Bleed Pipe Bolts and Studs 106 lb in Engine Cross member Bolts (Large) 107 lb ft Engine Cross member Bolts (Small) 92 lb ft Engine Flywheel Bolts (First Pass) 15 lb ft Engine Flywheel Bolts (Second Pass) 37 lb ft Engine Flywheel Bolts (Final Pass) 74 lb ft Engine Flywheel-to-Torque Converter Bolts 44 lb ft Engine Front Cover Bolts 18 lb ft Engine Mount Heat Shield Nuts 89 lb in Engine Mount Stud-to-Engine Block 37 lb ft Engine Mount Through Bolts 70 lb ft Engine Mount Through Bolt Nuts 59 lb ft Engine Mount-to-Engine Block Bolts 37 lb ft Engine Rear Cover Bolts 18 lb ft Engine Service Lift Bracket M10 Bolts 37 lb ft Engine Service Lift Bracket M8 Bolt 18 lb ft Engine Valley Cover Bolts 18 lb ft Engine Wire Harness Clip Bolt 37 lb ft Engine Wire Harness Ground Strap Bolt 37 lb ft Exhaust Gas Recirculation (EGR) Valve Bolts (First Pass) 89 lb in EGR Valve Bolts (Final Pass) 22 lb ft EGR Valve Pipe-to-Cylinder Head Bolts 37 lb ft EGR Valve Pipe-to-Exhaust Manifold Bolts 22 lb ft EGR Valve Pipe-to-Intake Manifold Bolt 89 lb in Exhaust Manifold Bolts (First Pass) 11 lb ft Exhaust Manifold Bolts (Final Pass) 18 lb ft Exhaust Manifold Heat Shield Bolts 80 lb in Exhaust Manifold Pipe Nuts 26 lb ft Front Shock-to-Engine Cross member Bolts 48 lb ft Fuel Injection Fuel Rail Bolts 89 lb in Generator Bracket Bolts 37 lb ft Generator Rear Bracket-to-Engine Block Bolt 18 lb ft Generator Rear Bracket-to-Generator Bolt 18 lb ft Ground Strap Bolt (at Rear of Cylinder Head) 37 lb ft Ignition Coil-to-Bracket Bolts 106 lb in Ignition Coil Bracket-to-Valve Rocker Arm Cover Bolts 106 lb in Intake Manifold Bolts (First Pass in Sequence) 44 lb in Intake Manifold Bolts (Final Pass in Sequence) 89 lb in Knock Sensors 15 lb ft Oil Filter 22 lb ft Oil Filter Fitting 40 lb ft Oil Level Indicator Tube Bolt 18 lb ft Oil Level Sensor 115 lb in Oil Pan Baffle Bolts 106 lb in Oil Pan Closeout Cover Bolt (Left Side) 106 lb in Oil Pan Closeout Cover Bolt (Right Side) 106 lb in Oil Pan Cover Bolts 106 lb in Oil Pan Drain Plug 18 lb ft Oil Pan M8 Bolts (Oil Pan-to-Engine Block and Oil Pan-to-Front Cover) 18 lb ft Oil Pan M6 Bolts (Oil Pan-to-Rear Cover) 106 lb in Oil Pressure Sensor 15 lb ft Oil Pump-to-Engine Block Bolts 18 lb ft Oil Pump Cover Bolts 106 lb in Oil Pump Relief Valve Plug 106 lb in Oil Pump Screen Nuts 18 lb ft Oil Pump Screen-to-Oil Pump Bolt 106 lb in Oxygen Sensor 31 lb ft Positive Crankcase Ventilation (PCV) System Strap Nut (at Right Front Vapor Vent Pipe Stud) 106 lb in Power Steering Pump Bolts 18 lb ft Power Steering Pump Bracket Bolts 18 lb ft Spark Plugs (Cylinder Heads-New) 15 lb ft Spark Plugs (all Subsequent Installations) 11 lb ft Throttle Body Bolts 106 lb in Transmission Housing Bolt 37 lb ft Valve Lifter Guide Bolts 106 lb in Valve Rocker Arm Bolts 22 lb ft Valve Rocker Arm Cover Bolts 106 lb in Water Inlet Housing Bolts 11 lb ft Water Pump Bolts (First Pass) 11 lb ft Water Pump Bolts (Final Pass) 22 lb ft Water Pump Cover Bolts 11 lb ft |
(Post 5920720)
Although, CZ28 search is working good; new owners of LS1tech have really fubar'd the search. I used to go there for more "technical" ls1 stuff, but have actually been searching here more lately due to a working search engine. |
(Post 5920744)
Cool :cool:
ummm
Front main? Goto www.ls1howto.com and you might find something in the cam/head swap section... the front main i hand tighten, very tight.....I didnt use specs for that... only specs i paid attention to was the cam retainer, gears for cam, crank pully,heads, rockers and thats it.
Thanks alot Marc, those will definitely come in handy.
I'll sticky this :)
Re: LS1 Assembly Torque Specs:
Just used this again, thanks :)
