CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   LS-1 or LS-6 Intake? (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/ls-1-ls-6-intake-240406/)
adam_3 Mar 22, 2004 07:02 PM
I was wondering if anyone knows if there are any distinguishing marks between an ls-1 intake maniforld? My car is supposed to have an ls-6, according to the guy I bought it from, but I think the mechanic may have screwed him.
Thanks,
Adam
mullettour Mar 22, 2004 07:26 PM
If it is a GM LS6 intake it won't have provisions for an egr valve. This is located directly behind the tb flange on a LS1 intake. If it is an SLP intake it could have egr on the LS6 but it should say SLP on it somewhere if that is the case.
ULTIMTEORANGESS Mar 22, 2004 08:07 PM
what year is this car?01-02 had an ls6 intake stock.
Florida_Z28_Boy Mar 22, 2004 11:10 PM
I don't know if you're interested in upgrading the intake manifold but if you are, you might want to look into the "LSX" intake and what type of setup it's meant for. Decide if it's right for your car.
adam_3 Mar 22, 2004 11:41 PM
The car is a 99z. I'll check for the egr, if it's there then I'll look and see if there is any slp markings on it. Is the lsx any cheaper than buying the slp ls6 manifold?
Florida_Z28_Boy Mar 22, 2004 11:44 PM
The LSX intake is like $800 or more I believe, I'll have to check.
It supposedly gives 15rwhp more than a LS6 though. Guess it's up to you to decide if that's worth it.
P.S: From what people on this board have told me, the LSX is the best intake out there unless you start looking at pure racing sheet metal intakes...that cost $2000+
adam_3 Mar 23, 2004 10:11 AM
Thanks for the input.
SSCamaro99_3 Mar 23, 2004 10:28 AM
No EGR, flat bottom (hrad to see on the car).
alteregoss2000 Mar 23, 2004 08:24 PM
I just put an (slp) ls6 intake on 00 ss and the new intake from slp has no markings on it anywhere. That was part of the reason I ordered from slp, because from a visiual look theres no difference. I perfer the bonestock look.
mrsneakyz28 Mar 23, 2004 11:08 PM
check for numbers or writing on it. I have a 99z and have an ls6 intake on it. The only reason i knew was because i had been racing some people when my car was stock and was a little bit faster than it should be. Someone looked at it and pointed out there was a part number written on the side like for an order.
