Are long tubes easier to install on a LS1??
Old Jul 7, 2004 | 02:01 AM
Black94mula's Avatar
I just installed LTs on a LT1 and I was wondering if a LS1 was easier to instal LTs on.
Old Jul 7, 2004 | 02:57 AM
99blackSS's Avatar
http://web.camaross.com/forums/showt...hreadid=237671 1/2 the problem for me was getting to the bolts closests to the firewall, although it is probably pretty hard on the LT1s too.
Old Jul 7, 2004 | 11:55 AM
colorchange96's Avatar
having done both, ill say the ls1 job was easier. mainly because the the spark plugs and wires are easier to hook up afterwords. both times i did it, i just drove the car up on ramps and then jacked it up a lil bit higher.
Old Jul 7, 2004 | 12:24 PM
Dark Angel's Avatar
LS1 is easier. It took me about 5 hours to get the headers in. I still haven't done the y-pipe though. I have the coated flowtechs. All that was needed was cut the flashing on the drivers side of the block and get the car high enough. The slipped right in and bolted up. No issues. Much easier then the set of Hookers I did a month ago, eve though they are the same design.
Old Jul 7, 2004 | 04:56 PM
robb4964's Avatar
LS1 headers are cake . I had no problems . But the LT1 headers I installed where a pain in the ars .
Old Jul 8, 2004 | 12:54 PM
SloLt1Z's Avatar
ls1s are way easier. Damned cheating LS1
Old Jul 8, 2004 | 05:40 PM
teke184's Avatar
check out page 11 of my cardomain site in the sig
i have a great write up on how to do it and pictures
Old Jul 8, 2004 | 08:53 PM
Nittanymarine's Avatar
They are alot easier to install. You might have to notch the k-member, or jack up the motor, or maybe disconnect the steering shaft. I only had to notch the k member, in my situation. If you do undo the steering shaft be sure not to turn the upper half. It may cause the airbags to deploy. Best of luck to you.
Old Jul 8, 2004 | 10:15 PM
robb4964's Avatar
You should not have to notch anything . On the drivers side , remove the bolt that runs thrue the engine mount and raise the engine as far as possible w/out breaking anything . ANd that Header will go straight in , n/p .
Old Jul 9, 2004 | 02:10 AM
Schantin's Avatar
Re: Are long tubes easier to install on a LS1??
In laymans terms....f*&^ yes it's easier on an LS1. A good estimate is 8 hours on an LS1 vs. about 4 days for an LT1.
Schantin
2002 Camaro Z28 M6
Former car 1997 Camaro Z28 A4 (With Jet-Hot LT's......the stupidest mod I ever decided to install myself In their defense, they worked great after a MONTH of adjustments, ripped knuckles, and exhaust burns from tightening the bolts and sealing leaks!!!!)
Old Jul 9, 2004 | 12:20 PM
spdmini's Avatar
it too me 2 hours to put on my entire exhaust... headers to tail pipe... but i cheated and used a lift
transam_388
Mar 15, 2015 11:53 AM
Cam's maro
Jan 30, 2015 09:21 PM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
SpeedJunkee
Dec 9, 2014 10:17 PM
Jul 4, 2005 05:00 PM
