CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   locking gas cap for 1999 camaro SS? (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/locking-gas-cap-1999-camaro-ss-244807/)
anasazi Apr 1, 2004 11:20 PM
where can i get a locking gas cap for my 1999 camaro SS?
does GM make one?
99blackSS Apr 2, 2004 02:04 AM
Stant makes one, Kragen carries them. They have a book there to look up the one you need.
anasazi Apr 2, 2004 07:13 AM
just called the local GM dealer and they claim GM does not recommend the use of locking gas caps ...
will those made by stant work without a problem? they carry them at the local discount auto
99blackSS Apr 2, 2004 03:34 PM
I'v had mine for almost two years now with no issues.:think:
MikeyG Apr 2, 2004 03:48 PM
We don't got no stinkin Kragen here in FL!:D
wu6fiend Apr 3, 2004 10:21 AM
I've got a GM one; just ask for the locking gas cap off a late model Monte Carlo, fits perfectly. Two years, no problems with it. BTW, take everything a dealership tells you with a grain of salt, they are often the last place you should be going for advice on your car.
alteregoss2000 Apr 3, 2004 10:32 AM
Is'nt that the truth.
Florida_Z28_Boy Apr 3, 2004 11:09 AM
Why wouldn't GM recommend using them :confused:
BISHOP Apr 3, 2004 12:01 PM
There is a chance of them throwing a SES light for the evap system if they do not seal properly. This can also happen with stock caps when they start to wear. I had a locking cap on my 97 for 5 years without any problems and almost 3 yrs with my 02 without any problems.
Florida_Z28_Boy Apr 3, 2004 12:04 PM
Ahhh ic now :cool:
USHotRod Apr 3, 2004 01:35 PM
Tell me about it. I have a new favorite "stupidest thing a dealer has told me." I was talking to one about the SSR they had on the floor w/the hood open and everything. He proceeded to tell me that it had the same engine as the Corvette. :mad: I was like "really? The corvette has a Vortech engine in it huh?"
wu6fiend Apr 3, 2004 08:22 PM
I've got another one, along the same lines. Bought my Firehawk used, and started to hear "clunking" noises from the rear end when turning at low speed. I have the Auburn rear, BTW. Took it into the dealership and inquired what lube belongs in the Auburn rear. "Auburn, whats that?" I explain. "Oh, you've put aftermarket parts in your car." I try to explan what a Firehawk is, and what SLP does to a new F-body to make one. Blank stares, no idea what the *&^% I'm talking about. "SLP, whats SLP?" "Whats a Firehawk?"
Bottom line, find yourself a good mechanic for the big stuff, and do as much of the small stuff yourself, and don't take your car anywhere near a dealer, once the warranty is up.
