locking the car
all of a sudden when i lock the car it only beeps once it's wierd i checked the doors and truck lid and still it only beeps once any one else's car do this all of a sudden i know this is a stupid question
Sounds like something has changed with your alarm settings. Take a look in the Owner's manual. It talks about how to change the settings to your liking.
The only time my car beeped once was when I forgot to push the trunk down all the way, but it sounds like you've already checked your trunk. I'm going to have to agree with LaSSt One's suggestion.
Mine does this every now and then, and its always the trunk/hatch. Even though it may be securly closed, the carpeting that goes around the latch gets caught up in there and causes the sensor to think the hatch is still open. Go back there, open your hatch and wiggle the carpeting and make sure none of it is covering any part of the latch. Then close the hatch again and see if it beeps twice.
Thats really odd because mine has always just beeped once when I lock it, and twice for un lock. I always attributed it to cylables. 1 = lock 2= un-lock
One beep from the alarm means that it's only partially set. I had that problem when I had an aftermarket alarm (Viper) installed, and had the system set to leave the dome lights on and dim after a few seconds upon closing the last door. For some reason with the dome on, the alarm still thought the doors were open. and wouldn't set. Weird poop...That one took me a while to figure out...
thanks alot every time i ask a question i get a number of great answers here it was the carpet holding down the little sensor thing
thanks alot |
well heres what my car does...take it for what it is......if i get out and push the lock button on my door.....close the door, and i push the lock button it beeps once.....if i get out of the car, and just push the lock button, it beeps twice, so whatever....just my .02 cense!
Its an option you can change how many times it beeps, just read your owner manual it tells you how
doesn't beep at all
mine doesn't beep at all...i know it has an alarm, but i bought it used and don't have manuals...
any help will do thanks guys |
Re: doesn't beep at all
Originally posted by ShayTal mine doesn't beep at all...i know it has an alarm, but i bought it used and don't have manuals... any help will do thanks guys |
| All times are GMT -5. The time now is 09:55 AM. |
