Lid problems?
I just got my whisper lid from tbyrnemotorsports and after putting it on, I can't get the clasps to stay shut. Is that a common problem or is it just me...maybe I didn't get it on right..??
clasps
are you sure the little flaps on the back of your lid are tucked in the slots. it wont clasp right if they arent.
:cool: Sometimes it depends on the bellows you have. It might be putting too much preasure on the lid and you have to trim it a bit:eek:
Woah, someone from Boca Raton....that's where I live....don't think I've seen your car around.
:cool: Depends on what part of town your in. Im in West Boca and only drive about a half mile to work a day. Rule 1 never work more then 1 mile from home. Rule 2 work only when bored:p
Okay, what do you say we get back on topic and help the little lady out? ;)
:D TTT |
make sure the front of the lid is behind the front of your airbox.i had the same problem.after i figured it out its been fine.
Re: clasps
Originally posted by hurricaine418 are you sure the little flaps on the back of your lid are tucked in the slots. it wont clasp right if they arent. |
Originally posted by JaysGone :cool: Sometimes it depends on the bellows you have. It might be putting too much preasure on the lid and you have to trim it a bit:eek: |
:cool: Jilly just trim the section at the throttle body end. If its the slp bellows its only silicon and a sharp razor blade will work fine. It will relieve the pressure at the back of the lid allowing it to slip in a little easier. I trimmed off almost 3/8ths to a half inch on mine. Still is a tight fit but much easier to remove to inspect the filter :eek:
Ok, well, I'll try it this weekend and see what happens. :)
| All times are GMT -5. The time now is 09:55 AM. |
