Lid or K&N FIPK???
Which is a better performance mod, the hi-flow lid (any brand) or the new K&N FIPK which replaces the whole airbox with just a simple oval filter? Which works better with a ram air hood?
Actually the difference between the two is fairly significant .... a lid will get between 10-12 rwhp. The FIPK will get at least 18 and typically more. Personally I got 22 rwhp with an FIPK.
An FIPK would be a good match with a ram air hood.
Good Luck
Good Luck
..I also heard that with out a ram air hood it will suck up hat air from in the engine bay. Although it is known that some people would remove the windshield washer bottle so it will suck up a hugs amount of fresh air.
????????:confused
????????:confused
Although it is known that some people would remove the windshield washer bottle so it will suck up a hugs amount of fresh air. ????????:confused
Good Luck
...like I said, that's what I heard, but then again you never believe what you hear sometimes. Although you could seal the air box only for the fresh air to come from below.
...all I know is that I like my lid, what I'm working on this winter is I'm building a custom intake. I'm having 2 tubes come from the 2 useless holes (not holes stock but I will cut out) in the nose of the car and I'm gonna cut 2 3.5 inch holes in my FTRA, weld it up and have nice fresh air added to my FTRA. I'll post pick when done.
...Cheers
...Cheers
war bird, are you pleased w/ you stealth box? Do you think it was worth the money? Im thinking about gettin that setup after I get a set of drag radials and the holly ls6 style intake. Just wanted to hear someones opinion who had the stealth setup
ram air with FIPK yeilds phenomenal boost. I have never dynoed the car, but holy **** I felt a difference, i did both mods together. Feels like I got at least 25 horse out of it. The FIPK also makes the car sound alot throatier.
Originally posted by TerrorDome
but doesn't FIPK run the risk of getting water in the engine? or too much dirt since it's so exposed? I want one, too but am worried about that
Now if you open up the bottom of an airbox with the !FRA mod or something like a FTRA, then yes. You've now exposed the intake directly to the road and in the case of a sealed FTRA that becomes the soul source of air. There have been several cases documented on the boards where someone has hyrdrolocked thier engine with these mods.
Likewise with the FIPK, if you drop the the cleaner fluid bottle and the shroud, the intake becomes exposed to debris and water on the road surface. Though probably less so than with an FTRA.
Good Luck
