CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   Leaking? (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/leaking-884433/)
mikeZ2878 May 31, 2016 07:10 PM
Leaking?
1 Attachment(s)
what is leaking? looks like the same color as antifreeze
94Z28LS1toLT1 Jun 10, 2016 04:13 PM
Re: Leaking?
Yes exactly same color,but looks like Freon it's around the ac compressor area. Probably have a Freon leak
mikeZ2878 Jun 10, 2016 06:58 PM
Re: Leaking?
I noticed as of late the AC does not work....It blows out warm air
94Z28LS1toLT1 Jun 10, 2016 10:25 PM
Re: Leaking?
Exactly I used to own a different 94 lt1 camaro n my ac was cold before but later on it got warmer n i found the same exact green stuff around the ac compressor
mikeZ2878 Jun 11, 2016 10:33 AM
Re: Leaking?
In other words I have a A/C refrigerant leak
94Z28LS1toLT1 Jun 12, 2016 12:40 PM
Re: Leaking?
Yea has ur ac blown cold before
mikeZ2878 Jun 12, 2016 09:14 PM
Re: Leaking?
Yes, it was blowing cold air
94Z28LS1toLT1 Jun 13, 2016 12:40 PM
Re: Leaking?
Yeah then it's for sure a Freon leak then,my lt1 did that before
shoebox Jun 13, 2016 04:32 PM
Re: Leaking?
Dye is usually in the refrigerant to help identify leaks.
mikeZ2878 Jun 15, 2016 02:13 PM
Re: Leaking?
Thanks for the help!
GaryDoug Jun 15, 2016 05:44 PM
Re: Leaking?
I thought the dye used in refrigerant was only visible by using a UV lamp. Is the leaking stuff liquid now? If so, it isn't refrigerant since that becomes vapor at normal atmospheric pressure.
shoebox Jun 15, 2016 08:16 PM
Re: Leaking?
Generally I think that is true about the dye, but it seems to be colored in normal light, too.
