Leaking?
Old May 31, 2016 | 07:10 PM
mikeZ2878's Avatar
Leaking?
what is leaking? looks like the same color as antifreeze
Old Jun 10, 2016 | 04:13 PM
94Z28LS1toLT1's Avatar
Re: Leaking?
Yes exactly same color,but looks like Freon it's around the ac compressor area. Probably have a Freon leak
Old Jun 10, 2016 | 06:58 PM
mikeZ2878's Avatar
Re: Leaking?
I noticed as of late the AC does not work....It blows out warm air
Old Jun 10, 2016 | 10:25 PM
Re: Leaking?
Exactly I used to own a different 94 lt1 camaro n my ac was cold before but later on it got warmer n i found the same exact green stuff around the ac compressor
Old Jun 11, 2016 | 10:33 AM
mikeZ2878's Avatar
Re: Leaking?
In other words I have a A/C refrigerant leak
Old Jun 12, 2016 | 12:40 PM
Re: Leaking?
Yea has ur ac blown cold before
Old Jun 12, 2016 | 09:14 PM
mikeZ2878's Avatar
Re: Leaking?
Yes, it was blowing cold air
Old Jun 13, 2016 | 12:40 PM
Re: Leaking?
Yeah then it's for sure a Freon leak then,my lt1 did that before
Old Jun 13, 2016 | 04:32 PM
Re: Leaking?
Dye is usually in the refrigerant to help identify leaks.
Old Jun 15, 2016 | 02:13 PM
mikeZ2878's Avatar
Re: Leaking?
Thanks for the help!
Old Jun 15, 2016 | 05:44 PM
GaryDoug's Avatar
Prominent Member
Re: Leaking?
I thought the dye used in refrigerant was only visible by using a UV lamp. Is the leaking stuff liquid now? If so, it isn't refrigerant since that becomes vapor at normal atmospheric pressure.
Old Jun 15, 2016 | 08:16 PM
Re: Leaking?
Generally I think that is true about the dye, but it seems to be colored in normal light, too.
94Z28LS1toLT1
May 12, 2016 09:28 PM
z28 justin
May 7, 2016 03:26 PM
cmaddox03
Mar 29, 2016 12:19 PM
25diesel
3rd Gen / L98 Engine Tech
Mar 12, 2016 12:24 AM
guitargod33
13
Jul 3, 2002 02:21 PM
