internal engine cleanser?
Old Feb 10, 2005 | 04:27 PM
blind527's Avatar
alright guys, i'll be getting my car back from the dealership tomorrow, and was wondering what a good cleaner for the internal components of my engine is. same thing with the transmission, thinkin about pickin up some lucas, it's in a white bottle. i'm going to be flushing out all the fluids from my engine transmission, radiator etc.
Old Feb 10, 2005 | 05:30 PM
DanBUCF's Avatar
Re: internal engine cleanser?
Seafoam!!!
Old Feb 10, 2005 | 05:36 PM
blind527's Avatar
awesome i'll go check it out, how is it applied just so i know for future reference how much is it?
Old Feb 10, 2005 | 05:48 PM
DanBUCF's Avatar
Should be a couple bucks...gets sucked in through the brake booster vaccum line. There should be instructions on the can.
Old Feb 10, 2005 | 08:41 PM
Bayer-Z28's Avatar
Sea foam woork great! The longer you let it sit in the engine the better it works. The lucas oil seemed like an extra 5 hp in a bottle when I had my Cavalier. I tried it in the LS1, it said compatable with synthetic oil, my lifters where ticking like crazy. I mixed it right.
Old Feb 10, 2005 | 08:50 PM
blind527's Avatar
how do i let it sit in my engine if i get it sucked through the brake booster line? dont' start my engine?
Old Feb 10, 2005 | 11:30 PM
DanBUCF's Avatar
Not sure about that one???? When I used it, I just let the motor idle and let it get sucked right in...about 2 minutes later, you'll start to enjoy the smoke show coming out of your exhaust!!! Pretty good idea to change your oil after doing this.
Old Feb 10, 2005 | 11:32 PM
blind527's Avatar
i honestly planned on it. i think the directions say on a warmer engine, pour slowly into brake booster line and let sit for about 5 minutes, i'll let sit for about 10-12 minutes and start your engine
Old Feb 11, 2005 | 07:36 PM
Robs97Z28's Avatar
use seafoam in the fuel tank, out it in the engine oil, and use it to clean the intake manifold and valves. It is great stuff!!
Old Feb 12, 2005 | 12:03 AM
99andMine's Avatar
Ive always just emptied the oil, left the old filter, and added 5 quarts of el cheapo tranny fluid, started it up and let it run for about 10-15 minutes. And DONT REV THE MOTOR, unless you like spun bearings. It'll smoke like a sob out of the exhaust, but it works well. And lucas...Ive used the hell outa Lucas oil additive and now am contributing it to collapsed lifters. Happened on my 4.3 blazer, threw one in my Camaro and started the same problem with less than 48k.
Old Feb 12, 2005 | 12:16 AM
mebanditws6's Avatar
The best cleaner to put in with your oil and clean out sludge is www.auto-rx.com. Avoid the engine flushes which are basically kerosene as those can be hard on seals, and unless you drop the oil pan and clean it, the sludge can get moved from the engine to the pan and clog the pickup screen. I learned all this the hard way on my Grand Cherokee I had when it was sludged up.
As for cleaning out the intake and the tops of pistons and valves, Seafoam or GM Top Engine Cleaner work very well. Both are the same except the GM stuff comes in an aerosol can from the dealership. Techron is pretty good for fuel injectors too.
Jason
D1SC383LT4
Jan 26, 2015 01:41 PM
ChrisFrez
Jan 11, 2015 03:47 PM
ChrisFrez
Jan 4, 2015 08:43 AM
Jul 4, 2005 05:00 PM
