CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   Installing Flowmaster muffler... (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/installing-flowmaster-muffler-340854/)
Harpoon Flyby Feb 12, 2005 05:27 PM
This post is not about Flowmaster performance. I do have a question about installing one. I am looking at the 80 series, of course. Specifically Flowmaster part#42583 2.5"in,dual 2.5"out. My question is installing it. Is it as easy as cutting the old muffler out with a sawsall, installing the muffler in it's place, and welding it in? I took some measurements of the stock muffler. I appears to be an inch or two larger than the Flowmaster. Any help would be appreciated.
Thanks,
HF
teke184 Feb 12, 2005 07:43 PM
Re: Installing Flowmaster muffler...
2.5" inlet would be a restriction...
the stock inlet size is 2.75"....so a better choice would be the 3" inlet/dual 2.5" outlet
just an fyi
and yes...your method is about all you'll need
99andMine Feb 12, 2005 09:30 PM
I put on the whole cat back system from flowmaster, even made the mistake using their clamps till i could get it to a shop to weld it. After putting it back on...the actual muffler wasnt hard to change. But I'd suggest using your own tips. The ones they supplied had a nice stamping of flowmaster, but one was about 1 1/2" to 2" longer than the other. But once broke in...BEAUTIFUL sound, nice choice!
codyss Feb 13, 2005 10:49 AM
Not to flame but a Flowmaster doesn't break-in.
And a 2.5" inlet is what you need not 3". The stock int. pipe is 2.75" but it reduces to 2.5 at the muller. If to are allready using a Flowmaster the restriction of the inlet wont matter. Going with a 3" inlet will make installing it that much more of a pain. Unless you don't mind using 2 feet of wire to weld the gap.
Harpoon Flyby Feb 13, 2005 06:05 PM
CodySS,
You are correct. I just got a set of calipers out and measured. It's 2.5" inlet to muffler, 2.5" outlet. Thanks much.
HF
teke184 Feb 13, 2005 06:50 PM
so you want your 330hp car breathing through a single 2.5" pipe...OK
:rolleyes:
Harpoon Flyby Feb 13, 2005 07:42 PM
teke184,
It already is. Besides I'm not here to debate it. OK?!
