CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   How often to change a fuel filter? (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/how-often-change-fuel-filter-227963/)
USHotRod Feb 22, 2004 09:27 AM
Basic question I know. But Im new at doing my own work. So how bout it?
ULTIMTEORANGESS Feb 22, 2004 09:29 AM
i change mine about every 15k.
USHotRod Feb 22, 2004 09:37 AM
Is it fairly easy or am I gonna have to drop the engine out again?:lol:
ULTIMTEORANGESS Feb 22, 2004 09:41 AM
very simple.its located near the rear on the drivers side.you may need to jack your car up a little to get to it but from there its self explanatory.
trust me im the worst with cars and i changed mine in 20 minutes.
USHotRod Feb 22, 2004 09:47 AM
Sweet! Thanks. :bow:
DenRS96 Feb 22, 2004 10:42 AM
Make sure you pull the fuse to the fuel pump or disconnect the battery.
USHotRod Feb 22, 2004 10:56 AM
Whoa!! Didnt know that. Thanks again. :bow:
Knowklew Feb 22, 2004 11:01 AM
www.installuniversity.com
look up the fuel filter install
Greed4Speed Feb 22, 2004 01:04 PM
Why?
The ignition is off and the pump isn't going to run w/it like that. Just hit the pressure release on the fuel rail (looks like a valve stem end) and you're good to go.
steelerfan Feb 22, 2004 02:38 PM
I just did mine yesterday for the !st time,i know that's just wrong but it's just something I didn't think much about.I checked out the instructions on www.installuniversity.com and it was a piece of cake ! The prep & clean up time took much longer than the actual install. I've heard every 10,000 miles is good
