How much HP? SC ?
Re: How much HP? SC ?
how much boost? go to www.superchargersonline.com and midway down on the right is a hp calculator. just plug in your existing hp and boost you want and it does the rest. a good estimate anyway.
20% over stock. It's definetly worth it, IMO. I am definetly looking into one when I get the $ to throw around. Stay at 6psi for now. You can allways add a smaller pulley for more boost. I believe 360 rwhp, not sure though.
Originally Posted by Antz97ZNJ
a blower even at 6 psi will give you way more then 360 rwhp
I mean with a stock motor. Yeah, bolt-ons and headers will help it out quite a bit. Like i said, I'm not sure.
The stock '01-'02 manifolds flow good, plus stock with a catback should be around 310-315 rwhp and 320-330 rwtq.
If he spends $6K for the kit and only 360 rwhp, I'd drive off a cliff
