how to get this hurst handle off
i've got a hurst shifter in my TA and people have told me that it simply screws off but that doesn't seem tobe the case. i can flex my handle about 15 degress both ways and it won't break lose, ofcourse i'm afraid of it breaking. what does it take to get the handle off the shaft? it doesn't make sense that is screws on because it has to be aligned. is i glued on?
I just unscrewed mine (counter-clockwise)
2001 TransAm WS6, M6 3.42
HPP, TBB, 160* t-stat, MTI Lid, Holley PowerShot, Flowmaster 80, Port/Polish MAF
2001 Z28
-- R.I.P. - 06/25/02
2001 Z28
<font face="Verdana, Arial" size="2">Originally posted by rncotton:
</font>
</font>
'02 35th anniversary edition camaro SS, 6spd, hurst, t-tops...K&N filter
<font face="Verdana, Arial" size="2">Originally posted by ScLeCo:
Grab it and twist WUSSY!!!</font>
-John
2002 Camaro SS #3513, Artic White, M6, T-top
SLP Loudmouth, K&N FIPK, BMR Shock Tower Brace
Do a couple of runs with and throw a shift as fast and hard as you can, thats how mine came loose, unintentionaly of cours.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
Borla (the expensive cut-out), Wisperlid W/K&N, FRA, Cags eliminator, Strange 4.10's, G2 Rear Girdle, Valv. Synthetic 10W-30, Redline gear oil, Fat hurst shift ****, Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev K2's, Focal utopia 6" audiom midrange.
Soon to be:
Like already stated, it should just screw off and it will be difficult at first because there is some kind of thread lock on it from the factory. If it's not a factory shifter you may want to check to see if it has a small set screw at the base of the shift **** that needs to be loosened.
[This message has been edited by PAGregSS (edited July 24, 2002).]
Did it work? I've had the same question. I havn't twisted hard enough yet to get mine off either. I will have to soon cuz I just ordered the Hurst original cue ball style today.
02 Z28 DARK METALLIC BLUE M6 HURST QTEC STB GLB SLP-Lid Trailerin hitch
Got the cue ball in today. The stock one DID just twist off. Just had to try harder. It looks like it they used some yellow RTV or sinmilar when it was put on at the factory.
tommalcolm
Sep 11, 2015 03:39 PM
CARiD
Sep 7, 2015 08:21 AM
