CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   How do you check......? (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/how-do-you-check-272549/)
CrippleFightin Jun 15, 2004 07:35 PM
How do you check if the valves are messed up without taking the heads off?
Also, how would you check to see if a coil is bad not knowing which ones work and which dont?
Gracias!
mullettour Jun 15, 2004 07:53 PM
You can do a compression and leakdown test for the valves, not sure about the coils though.
teke184 Jun 16, 2004 06:34 AM
a scanner that can monitor misfire i would think you could determine which coils are bad. and if you suspect a particular one, swap it around with another one...see if the misfire follows
