How do I add trans fluid to a 1999 z28?
I need to add transmission fluid to my automatic z28 due to a leaking gasket, where and how do I do this? I have dextron III trans fluid, I also need to know how to estimate how much it needs.
Re: How do I add trans fluid to a 1999 z28?
Add it via the trans dipstick. To check level run the car and leave it idling the check the dipstick.
it needs to be added through the dipstick. they have special funnels that fit in there to make your life easier. as for the fluid itself, you need dexron VI. dexron III is not a good idea.
