Which Holley pan for the '69 Camaro
Holley offers two pans, the 302-1 and the 302-2, one with more clearance and the other with a bit more capacity.
Does anyone know for sure what fits a '69 Camaro? I'm not sure if the smaller one is for the S10 or if maybe the Camaro also needs the extra clearance... but they don't seem to say. Thanks! |
Re: Which Holley pan for the '69 Camaro
Not 100% sure, but here is some info that may help with you in deciding which pan to use.
The 302-2 pan has additional items that will be needed to make the application work with this pan according to Summit: Requires use of LS3 dipstick (GM part number 12634547) and tube (GM part number 12625031). See the “required parts” tab. Designed to use a GM F-body windage tray, GM part number 12558253. A modification to the windage tray is required to provide clearance to the pick-up tube. A full-length windage tray may be used if the front quarter of the tray is removed. See the attached instruction sheets to see the windage tray modifications required. Engine location may need to be adjusted (up/down or forward/after) for crossmember or steering linkage clearance, depending on the vehicle, steering configuration, or chassis type. As for the 302-1 pan there is no additional requirements. This may be a better route based on the fact that there is no additional cost to worry about with getting this pan. Both pans will work for your LS engine with slightly different dimensions, but should fit with your 69 Camaro OEM specs. Here is a comparison of both pans in a link below. hope this helps with your decision. http://www.jegs.com/images/photos/50...comparison.jpg |
