CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   Help!!!how to remove drivers seat... (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/help-how-remove-drivers-seat-56049/)
stik6shift98 Dec 8, 2002 03:29 PM
how do i get it out.....theres no bolts that i can get to...
Kwiksilverz28 Dec 8, 2002 04:17 PM
Move the seat forward or back. Get the 2 bolts there (you have to pull the robber caps off the studs), then move the seat to the opposite position and get the other 2. If the seat is stuck, you have to get under it with a wrench. Not fun, but doable.
Let me know if this doesn't help.
stik6shift98 Dec 8, 2002 04:25 PM
thats kinda hard to do with battery unplugged....
ill try it...
and do u know where to get mounting brackets for racing seats...r1 racing seat
or does anyone
thanks:bow:
wilbs600 Dec 8, 2002 04:27 PM
First i got the front two nuts off then I put the seat all the way forward and got the rear nuts off. I know there is a plastic piece over it but just bend it a little or maybe you won't even have too. Before you pull the seat out make sure to disconnect the power seat wires from the seat so you don't break anything. Good luck.
stik6shift98 Dec 8, 2002 04:36 PM
thank you:D
hopefully all will go well
i need the mounting brackets still
