Help!!!how to remove drivers seat...
Move the seat forward or back. Get the 2 bolts there (you have to pull the robber caps off the studs), then move the seat to the opposite position and get the other 2. If the seat is stuck, you have to get under it with a wrench. Not fun, but doable.
Let me know if this doesn't help.
First i got the front two nuts off then I put the seat all the way forward and got the rear nuts off. I know there is a plastic piece over it but just bend it a little or maybe you won't even have too. Before you pull the seat out make sure to disconnect the power seat wires from the seat so you don't break anything. Good luck.
Henson071
May 4, 2015 12:23 PM
squarehead
Nov 21, 2014 08:02 PM
