Help with coolant light......
OK,me being an idiot I put injector cleaner in the radiator thinking it was my watter wetter
I only dropped about 2 oz before I realized my mistake.I was at a car show so I had to drive it home about 25 miles.So I start driving and I get the little coolant light on the dash.I get home and flush the radiator until nothing but clear water is coming out.I reset the battery by pulling the PCM fuses but the lights still there.The car runs fine and doesn't overheat or anything and I think I just damaged the sensor that lights up the dash.Does anybody know what it's called and where it's located?Thanks.
Kevin
1998 Black Z28 A4
-------1/8-------
8.548 @ 83.64 MPH
Pics
Camaro/Firebird Birthday Bash
I only dropped about 2 oz before I realized my mistake.I was at a car show so I had to drive it home about 25 miles.So I start driving and I get the little coolant light on the dash.I get home and flush the radiator until nothing but clear water is coming out.I reset the battery by pulling the PCM fuses but the lights still there.The car runs fine and doesn't overheat or anything and I think I just damaged the sensor that lights up the dash.Does anybody know what it's called and where it's located?Thanks.Kevin
1998 Black Z28 A4
-------1/8-------
8.548 @ 83.64 MPH
Pics
Could actually be coincidence, as I have been thru 3 of those low coolant sensors - counting the factory original unit !
My guess is that it has been "coated" and is therefore unable to read the level.
I guess you will have to remove it from the radiator to clean it (wipe off the coating) as I do not believe tehre is any way to reach the wetted end while it is installed, but if I am incorrect on this someone should chime in to correct me !
To answer your question, it is located on the passenger side of the radiator right below one of the a/c hoses - you'll see a little gray plastic piece with an electrical connector on it.
I also understand that this was such a problem on the 98's & '99's that they did away w/ this little jewel for the '00 model year.
Good Luck , and watch out for battery terminal corrosion !!
(See my post about the original battery.)
Britt
'99 T/A
Best 13.071 @ 104.92
Now own '99 SS # 2073 !
12.969 @ 105.44
Britt
'99 T/A
12.969 @ 105.44
i think it is located on the radiator tank below the cap.
the part # is 10096163 and i think it is around $53.00.
mine went bad about 2 months ago so i dug out the paper work on it for you,hope this helps.
99 Camaro Z28
blue/grey 31,000 miles
LS1 A4 flow-pro exhaust
99 Camaro Z28
Thanks for the quick responce guys.I took out that little sensor and cleaned it really good.It was covered in gunk.Once I did that I put it back in and it worked like a champ.The idiot light's gone!Thanks again!
Kevin
1998 Black Z28 A4
-------1/8-------
8.548 @ 83.64 MPH
Pics
Kevin
1998 Black Z28 A4
-------1/8-------
8.548 @ 83.64 MPH
Pics
This is a shining example of a perfect post.. no issues.. just facts... AND the poster responded with his findings and THANKED EVERYONE.. Thats why I keep coming here...
BRAVO!
Psycho Cabbage
2002 Camaro Z28
(6 sp) Bone stock
Webmaster for RaceHer.com
Check out the current polls and vote!
by the prěcking of my thumb, something wicked this way comes
-Traded in- 1995 Camaro Z28 (A4 (#6 I might add!),ES tranny mount and torque arm bushing,SLP CAI,ASP 34% Underdrive,Strange 3.73's (shredded Auburn),1LE alum driveshaft & intake elbow,Yokohamas AVS Intermediates,160-stat,MAF screen removed, HPP+(for shift points only),Borla Y-pipe, Flowmaster Force-II catback, Gutted Cat, Airlift Airbag, !TB Bypass, J&M LCA's, Bosch Platinums, Moroso BlueMax Wires, Free RamAir, Meziere Electric H2O pump, MAC 3point STB, BMR Panhard, SCR SFC's
Just installed:Nu-tek Heads (mild port) and Comp Cams 1.6RR's! New track and dyno #'s to follow!
best 13.44 @103.26
0-60ft 1.96
270 RWHP/296 RWTQ
0-60MPH 4.8sec
1987 Porsche 944S (waiting on LT1 mod)
BRAVO!
Psycho Cabbage
2002 Camaro Z28
(6 sp) Bone stock
best 13.44 @103.26
0-60ft 1.96
270 RWHP/296 RWTQ
0-60MPH 4.8sec
Formula Steve
Sep 19, 2023 08:31 AM
