Help on bleeding brakes!!
Old Oct 3, 2003 | 03:06 PM
kclegends17's Avatar
I need to know how to bleed the back brakes. Thank you very much.
Old Oct 3, 2003 | 03:12 PM
2001NBMZ28's Avatar
http://www.ls1camaro.net/sections.ph...ticle&artid=60
Old Oct 4, 2003 | 05:08 PM
Mikie's Avatar
The link above is great , but just to show you how easy it is...
Lay down behind the rear wheels and feel around on the caliper for the port. Pop off the rubber dust cap with your fingers and slide the correct millimeter wrench on it. Have someone to pump up the brakes for you and yell for them to hold them. Turn the fitting and the brakes will go to the floor, tell them to hold them there until you tighten the fitting. Its really the same as the front.
Just a note to you though,,, You know there is an order you are supposed to bleed in right?
Your supposed to bleed the farthest away from the MS first and work your way closer. Ive done it either way and it is not a big deal if you dont follow that pattern , but just letting you know the correct way.
Later
Mike
Old Oct 4, 2003 | 05:16 PM
Mikie's Avatar
I took a pic for you....http://mikie.cz28.com/images/brakes.jpg
Formula Steve
Sep 19, 2023 08:31 AM
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
1bad427ls1
Sep 23, 2015 01:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
