CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   heads and cam ? (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/heads-cam-525710/)
Snugans310 Jun 10, 2007 01:12 PM
heads and cam ?
I have a 2002 camaro ss m6 with slp lid,ls6 intake,freemods,cutout, and i have
othermods in my room i have not installed yet like my underdrive pulley,3:90
gears,pacesetter longtube headers , ok do you guys think that a pair of ls6
heads and this cam Thunder Racing Custom Camshaft
"Reverse Split" - 236/230 .599/.575 112 LSA with all that stuff installed and
tuned what kinda numbers will i be seeing at the dyno but give me advise on
what cam to go with Thanks
Snugans310 Jun 10, 2007 01:24 PM
ohhh yeah and i have 67,000 miles on the car
myslowcamaro Jun 10, 2007 02:27 PM
id get a better set of heads
smallblock458 Jun 10, 2007 06:05 PM
I've got a set of brand new patriot stage 2- 2.05 1.6 59cc head's for sale that I got for $1000 from E-bay if you want them make an offer. I spent a lung on a set of Trick flow's instead of using the Patriot's.
Snugans310 Jun 10, 2007 07:42 PM
what r u guys talking about i didnt ask that
2000slp2768 Jun 10, 2007 07:57 PM
they are saying to buy better heads.
Snugans310 Jun 11, 2007 09:17 PM
i know that but i asked what would i see at the dyno with what i posted
smithtim Jun 12, 2007 09:15 AM
big cam = good
Originally Posted by SSpdDmon (Post 4554328)
Keep in mind - picking a cam is kind of like picking out your own weiner. :lol: You want to go big, but not too big, and most of all, not too small.
tons of old post on this, here is a link to a search
http://web.camaross.com/forums/searc...archid=1675970
best of luck
tim
Kraest Jun 12, 2007 10:31 AM
There's nothing wrong with Patriot Performance heads in my experience. I have them on my 408 and they work wonderfully. I think the problem that people have with them is that they don't have enough cubes to use them, since PP ports the living **** out of their intake runners from what I've seen.
I'm not a fan of reverse-split cams at all unless you're going with a forced induction setup... I'd stick with a regular split duration cam like the F-13, F-14, TR 230/236 or Trak.
Mike
obzidian Jun 12, 2007 12:49 PM
right, my thoughts exactly, i believe that cam might not be well suited for a n/a setup.
Heres a thought, what kind of numbers and drive characteristics are you looking for?
Something that is peaky or a setup that will get you a good swell of power in the midrange and possibly not make so much on top.
Also, do you plan on going with more CI or forced induction/spray?
Snugans310 Jun 13, 2007 04:52 PM
im looking for like 400 rwhp and im cool with that ill be happy with that
Kraest Jun 14, 2007 08:06 AM
You can do 400rwhp with a cam-only setup. No need for aftermarket heads if you're only looking for 400.
I suggest the Futral Motorsports F-13.
