Headlight problem, help!
I usually post in the v6 forum but i thought you guys might be able to help on this topic.I have a 98 firebird, and at first my driver side headlight would not come up. I tried turning the manuel **** to fix the problem, now its making a grinding noise when it goes down. I had this problem 2 years ago and we fixed, but i forgot how. I know about the gear switch thing, but on 98 the case where the gear is located in is joint so you can't get the gear out, i looked at the webpage brentz, but that just tells me how to switch the gear and i can't do that. Could it be one of the levers acting up. Thanx
ChrisFrez
Feb 15, 2015 08:12 AM
