CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   headers (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/headers-301634/)
STMWS6 Sep 16, 2004 01:26 PM
headers
I have a 1998 camaro m6 I have the loud mouth exhaust what are the best headers to go with that are the high flows cats good to get to.
Sean
teke184 Sep 16, 2004 01:47 PM
Re: headers
do you have to pass visual inspection or just sniff test?
long tubes with high flow cats is the way to go if its only sniff test.
stuck with shoties if not
STMWS6 Sep 16, 2004 09:35 PM
Re: headers
what are a good kind of long tube
Onez4u2bn Sep 17, 2004 12:15 AM
Re: headers
QTP, Good ground clearance and You can get the high flow ones which are better. Gonna cost ya though. www.quicktimeperformance.com Probably they best ones out there.
darrens99formul Sep 17, 2004 09:22 AM
Re: headers
WARNING!
Loudmouth + LT headers = loud, raspy and extra drone. Some like it but most do not. You'll also likely attract the attention of every cop in a 5 mile radius when you get on it. If you want to keep the loudmouth then I highly recommend you get HF cats to help quiet the setup down a bit and eat up some of the rasp. You may even want to consider swapping the resinator for a 18" bullet muffler.
As for brands I agree with QTP. Kooks are also top of the line. As for bang for the buck budget headers then the newer pacesetters are a good value.
Good luck
mebanditws6 Sep 17, 2004 11:16 AM
Re: headers
Pacesetter or Flowtech makes good long tubes for the price. The Pacesetter Y pipe is a POS though from what many have said. You ought to get Texas Speed's catted Y pipe. Plus they're the cheapest right now for Pacesetter LT's.
Jason
Mindgame Sep 17, 2004 12:20 PM
Re: headers
QTP, Kooks & TPIS.
I'd recommend any of those. Only one's I've seen first hand though. Ground clearance is good as is build quality.
-Mindgame
STMWS6 Sep 17, 2004 09:25 PM
Re: headers
where can I find kooks or tpis what exhaust would go good headers.
AL SS590 M6 Sep 18, 2004 04:38 AM
Re: headers
I have Dynatechs Long tubes on the 'bird. Great fit and good clearance. But they come real close to the oil plug on the pan. So close that I had to remove the magnet to shorten the plug to get it in and out.
STMWS6 Sep 18, 2004 05:16 PM
Re: headers
I was looking at the Complete Header Kits with header cat and the y pipe that are coated. i found TPIS
Dynatech I want Long tubes is that any other good ones if so what ones and what web site are they on.
STMWS6 Sep 20, 2004 01:49 PM
Re: headers
Are the Jet hot long tube header with there high flow cat and y pipe any good or is the TPIS or the Dynatech with one is the best and where would I get it from
BirchMan98z Sep 20, 2004 05:57 PM
Re: headers
Originally Posted by darrens99formul
WARNING!
Good luck
He's got an M6 car. We have a slight advantage over the auto guys, we can decide how loud we want our car to be while we're driving.
BirchMan98z Sep 20, 2004 06:00 PM
Re: headers
Depending on your budget, I would recommend the FLP (Finish Line Performance) setup. You have the option of catalytic or offroad, everything is coated, easier install than most, and it's just a great system. I've helped many people install these, and everyone has been extremely pleased with them.
teke184 Sep 20, 2004 09:00 PM
Re: headers
i love my flowtechs!!
coated headers, orp, gaskets, clamps, and blockoffs for under $600
check out the pics on page 2 and 11 of my webpage in the sig
