Harsh 1-2 shift
Harsh 1-2 shift
4L60E, 2000 Camaro
Anyone on this board know about valve bodies? My 1-2 shift is abnormally firm and slightly delayed. All other shifts are smooth. Stock trans tuning. What is the first thing I should check? Replace 1-2 solenoid? I changed the fluid and filter not very long ago. It did not help.
Originally posted by poniekiller
No. It's the trans.
No. It's the trans.
Viper
Viper (isn't that a Dodge?!?) could be right. Some engine management problems will cause the PCM to spike line pressure, especially if it can't accurately tell engine load and determine how much line pressure the trans needs. If your engine is ok then the things to check are: #8 and #1 check ***** for proper location. If the trans has never been messed with they are probably in the correct locations, check the spacer plate for peening where they seat. If the plate is damaged then replace it. Also check the 1-2 accum. for a split seal or binding in the bore or on the shaft. Make sure the accum. spring isn't broken. Check the 1-2 shift valve for binding. Check the 4-3 sequence valve, I think it's the 4-3, it may be the 3-4. There's only one and it's purpose in second is to control the bleed of the 1-2 accum. oil. If it's sticking the fluid won't bleed and cause a harsh second. Also check the spring under the bottom servo piston, if it's broke it won't cushion the band apply. Also, not all codes will turn the check engine light on. Some need to see two or more failures before the light comes on so you may have a code stored, no light on, waiting for another failure. Emissions failures will turn the light on ASAP. Trans. concerns typically don't turn it on as quick. Let us know how you do. Good luck.
WobblySausage
Oct 7, 2015 10:09 AM
