CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   hardened pushrods yes or no? (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/hardened-pushrods-yes-no-312792/)
Michael Ozorowsky Oct 26, 2004 12:46 PM
I hear back and forth about hardened pushrods. Do you guys recommend putting hardened pushrods with aftermarket heads/cam/springs?
LT-14me Oct 26, 2004 01:27 PM
Re: hardened pushrods yes or no?
yes you have too. Stock pushrods are not strong enough to handle it
mc01ta Oct 26, 2004 02:18 PM
Use the search button, I noticed you posted 3 separate topics in a row, SEARCH BUTTON is our FRIEND!!!!!!!!!!!!!!!!!!!!! Seriously tho, you would b suprised how much good info we have in our archives.
Capn Pete Oct 26, 2004 05:16 PM
I wouldn't install any cam without upgrading pushrods. Heard too many horror stories about them even with stock cams:rolleyes:.
Michael Ozorowsky Oct 26, 2004 05:17 PM
k, thanks searching now.
AL SS590 M6 Oct 27, 2004 04:54 AM
Yes
Michael Ozorowsky Oct 31, 2004 09:13 AM
ok, dumb ? here what length? Do I just ask whoever I buy the cam from?
Mindgame Oct 31, 2004 11:59 AM
"....aftermarket, heads, cam, springs...."
You will have to check and see what the correct length is. Cam base circle, rocker arm design, installed valve height and many other factors play into choosing a pushrod length. Don't assume anything.
Buy a pushrod length checker from Comp and follow the instructions, then order the pushrods you need.
The strongest pushrod you could buy is going to be a tapered length like Manton, Smith Brothers etc..
-Mindgame
Michael Ozorowsky Oct 31, 2004 02:19 PM
what about chromoly?
