Gtech - Tazzo numbers....?????? What U got?
Old Aug 12, 2002 | 10:15 AM
Btchslp's Avatar
Arrow Gtech - Tazzo numbers....?????? What U got?
I have run with the Gtech meter and my buddy has the Tazzo , both measure your 1/4 mile speeds, very accurate I might add. We used them at the track and they both were within a tenth of a second accuracy.
My numbers are in my sig, what have you guys come up with...?
99 SS, Dark Metallic Blue, M6
SLP lid, KN, TBB, SLP Y-pipe, SLP loudmouth
ported MAFs, Nitto 315 DRs
Currently: 1/4 13.06@113.8, 0-60 4.77 (w/passenger) Gtech'd
12.99@110.2, 2.06 60ft - Tazzo.
Old Aug 12, 2002 | 02:25 PM
redz_02's Avatar
Post
I ran a 13.8 at 107 MPH with a g-tech, and about 400 lbs. of extra passengers without me and a full tank of gas. That was about 3 months after i bought my Z and without the 4.10's. Can't remember my 60 but i had a bad luanch.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
Borla (the expensive cut-out), Wisperlid W/K&N, FRA, Cags eliminator, Strange 4.10's, G2 Rear Girdle, Valv. Synthetic 10W-30, Redline gear oil, Fat hurst shift ****, Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtrpro 1000, Kicker 12L7 in a milhouse, Focal polykev K2's, Focal utopia 6" audiom midrange.
Old Aug 12, 2002 | 07:02 PM
PhantomTA's Avatar
Moderator
Post
Just remember the G-tech is high on the MPH..
usually between 2-4 mph high
DaveD
1998 WS6 #207
-ARE Stage II Head/Cam
1998 Regal GS
-It Has Boost
The Phantom of CamaroZ28.com
Http://PhantomTA.cz28.com
Old Aug 13, 2002 | 08:57 AM
hrtbeat2's Avatar
Question
Do you guys think its worth buying??
Old Aug 13, 2002 | 03:44 PM
Btchslp's Avatar
Wink
Totally worth buying, I used it at the track many times and it was right on within a few hundredths.01 of a second of what the track gave me (when I had my 94 Vette, I have not gone to the track yet in my SS). I picked mine up for $75 because my buddy was buying the newer Tazzo. The Gtech typically reads 5 mph high, don't know why, but that seems to be the general number. We ran the Tazzo and Gtech at the same time, they were very close to each other on every run. You can also do a HP reading with the Gtech and it gave me 331, which is incredibly close to what others have dynoed with my mods. So any other numbers, 0-60, 1/4 mile...???? Mine are in my sig.
Old Aug 14, 2002 | 10:10 AM
Btchslp's Avatar
Arrow
Numbers...?
Old Aug 14, 2002 | 10:45 AM
cyrixxx's Avatar
Post
These things measure using things that measure acceleration right? Why don't they make GPS meters. I would think those would be about as acurate as you could get.
Old Aug 14, 2002 | 11:05 AM
Camaro ChriSS's Avatar
Post
I've used my getch at the track and the street, and the numbers have been very accurate. As mentioned, mph is higher by 4 mph or so.
I've never had good luck with the hp readings though - it's usually off for most people I talk to by 50-60 hp or so. Someone once made up a formula that was fairly accurate for converting the gtech dyno #'s into what you should get on the dyno.
btchslp, what fornula did you use? Or did you use one?
2000 Pewter SS #C161
SLP Dual-Dual, Bilstein suspension, Eibachs, 21mm/35mm swaybars, GMAF
SLP CAI w/lower plate, !EGR, Direct-Flo, SLP STB, Ported TB, ASP Crank pulley
SLP/AAM Differential cover, SLP 2600, Powershot, MSD wires, NGK's,
BMR Boxed LCAs, BMR PHB, G2 DSL, Nitto 555R, Heavy Lead Foot...
http://community.webshots.com/user/murlynd
Old Aug 14, 2002 | 01:41 PM
Btchslp's Avatar
Arrow
I didn't use any formula to calculate the HP. You are required to put in the running weight of the car + driver/passengers. I used 3750 lbs for me and a 150lb passenger and the result was 331 hp. This number seems incredibly accurate, although I haven't dynoed yet (I am in a few weeks) people with my year and mods are getting right around 325-335. In fact, GM High Tech Perfomance mag just put out an article in which they dynoed 335rwhp with an 01 TA with a lid, slp maf, BB cat back, and smooth bellows....note again 335rwhp. My mods are almost identical with maybe a few extra in my favor so if anything the gtech read low.
Old Aug 14, 2002 | 03:47 PM
Btchslp's Avatar
Arrow
A GPS doesn't update fast enough for accurate 1/4 times, they update every second, hardly fast enough as compared to a Gtech meter or Tazzo that is in mili-seconds.
Old Aug 14, 2002 | 07:47 PM
redz_02's Avatar
Post
Plus using GPS would be alot more complited, would need an antenna like the XM radio, would have to update it, and would probably be alot more than 150 bucks.
Soon to be:
Old Aug 14, 2002 | 07:50 PM
bird killer #2's Avatar
Post
I ran a 13.08 with two passengers.
2002 navy blues SS slp air box and dual/dual exhaust 345 hp (a4)12 disk cd changer
SLP SS grille 10spoke chrome rims
T-Tops.................
2002 Maroon Chevy Silverado..Mods: K&N Air System, Hypertech power programmer III, and a Throttle Body Bypass.
Old Aug 15, 2002 | 09:55 AM
Btchslp's Avatar
Arrow
Bird Killer, do you remember what your mph was or 0-60 times were....? How many times did you run?
Currently: 1/4 13.06@113.8 (gtech runs high in mph by about 4mph), 0-60 4.77 (w/passenger) Gtech'd
Old Aug 15, 2002 | 11:18 AM
CASPER97TA's Avatar
Post
G-TECHS READ WAY OFF ON THE 0-60 TIMES. 4.77 IS WAY TOO LOW. IT'S PROBABLY AROUND 5 FLAT.
Old Aug 15, 2002 | 12:16 PM
Post
<font face="Verdana, Arial" size="2">Originally posted by Btchslp:
</font>
It was 4.76 I ran 5 times and that was my best. But i was running consistant low 13's. It all depends on weather. It was real cold that night. When i run in the summer 13.5 is my best..
