GM Technical Bulletins
Does anyone know where to look up GM Tech Bulletins? I have a couple I would like to find and read up on. Thanks in advance...
You got the numbers for them? I'll see if I can hook you up.
I use to have a very good web site but some how I lost it, this might be of some help www.nhtsa.dot.gov/ .
Al |
THANK YOU!!
Originally posted by rncotton You got the numbers for them? I'll see if I can hook you up. |
Well, for whatever reason, the number structure on my list is different.
Do you have the Titles for them? (i.e. what symptom?) I only have detailed access to TSB's effecting the 2001 model year, but a lot of them span multiple years. |
I'm sorry
Hey Buddy,
I'm sorry, these are tech bulletins for a '95 Geo Prism. I thought you were a GM technician or something. Thanks just the same. Take care.............Brent |
'95 Geo ... well that explains why I couldn't find it under '01 F-Body. :)
No problem ... if I might make a suggestion ... have you tried searching for these with the Google.com search engine? |
Originally posted by rncotton '95 Geo ... well that explains why I couldn't find it under '01 F-Body. :) No problem ... if I might make a suggestion ... have you tried searching for these with the Google.com search engine? |
| All times are GMT -5. The time now is 08:32 AM. |
