CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   gears in LS1 (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/gears-ls1-46765/)
mook99TA Nov 12, 2002 03:42 PM
gears in LS1
I cant get the same answer from anyone what gears are stock in a 99 TA?
bbentley40 Nov 12, 2002 03:47 PM
I think it can range from 2.73's, 3.08's, 3.23's or 3.42's. Best way to find out is look at your RPO code in your door and look for one of these values:
GU2 Axle, Rear 2.73 Ratio
GU4 Axle, Rear 3.08 Ratio
GU5 Axle, Rear 3.23 Ratio
GU6 Axle, Rear 3.42 Ratio
Hope that helps.
PhantomTA Nov 12, 2002 03:55 PM
Actually 3.08's are not an option on 94-02 f-body's
Z-Attitude Nov 13, 2002 07:58 AM
I thought the 3.08 rear is in the v-6 f-bodies. M6 is the 3.42
96fbirdA4 Nov 13, 2002 09:13 AM
No, he's correct. Technically 3.08's are not an option on any 94-02 F-body, they are standard on v6 f-bodys with A4 transmission. :D I should know, I had one with 3.08's :)
3.42's were optional and came on A4 V6's with the W68 or Y87 package.
V8 F-body's couldn't get 3.08's from the factory however.
PhantomTA Nov 13, 2002 10:41 AM
Maybe i should have said v8 f-body. but since we are talking about this guys 99 TA i didnt think id needed to include the v6 ?
ForbesSS Nov 13, 2002 11:53 AM
A4=3.23
M6=3.42
PhantomTA Nov 13, 2002 12:21 PM
actually for V8 F-body
A4 - 2.73 Standard
A4 - 3.23 Optional (Standard on SS, Firehawk, WS6)
M6 - 3.42
