CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   FTRA question (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/ftra-question-13801/)
mustang_52 Jun 17, 2002 04:44 PM
FTRA question
Just got my kit and i'm excited to put it on but I have a few questions regarding the seals provided. It came with two foam pieces and one rubber seal. According to the instructions there should be 3 pieces of foam. Also are there any real good pics of where they should be placed because its hard to understand the instructions. thanks
2001NBMZ28 Jun 17, 2002 09:21 PM
My kit came with 1 rubber seal (for the front of the airbox) and 2 adhesive foam pieces (to seal the bottom of the box). The 2 large foam pieces are just package material, but some use one as a quick block off plate in case of an emergency. You can go to http://www.fasttoys.net and get better pictures, but the instructions are the same. I think their forum is operating again too.
A4 (3.42)/Whisper Lid/Corsa Catback/FTRA/BMR/160+Tstat/SLP Fan Switch/HPP3
mustang_52 Jun 18, 2002 04:35 PM
OK, my fault, I just found the 3 peices of foam that they are talking about. I guess once I start taking things apart I will see where they go. thanks
Camaro ChriSS Jun 19, 2002 03:05 PM
I ended up buying more foam to seal the box better. There were a few leaks (I tested it with a leaf blower) that I found around the edges.
