CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   Filling a Hole (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/filling-hole-76303/)
brewski4u1 Feb 1, 2003 11:57 PM
Filling a Hole
ok heres the deal i got a set of 02 sims and now i need to find a way to fill the hole that the 02 sensors were in what can i use does anyone have any bright idea's. i was thinking take it to a muffler shop and just have them weld it closed. i had a friend who tried JB weld and the stuff blows big time hard as steel my a$$, i think super glue is stronger then that stuff.
toykilla Feb 2, 2003 04:34 AM
Have it welded!! You might as well do it right the first time than to mess around with JB Weld and risk exhaust leaks....
kjlvilla Feb 2, 2003 08:41 AM
If you can't find a muffler shop to weld the holes, because it would be tampering with emissions, go to the junk yard and they'll probably give you a couple of O2s. Cut them to fit so they don't stick out.
