CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   Faulty Window Under Warantee (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/faulty-window-under-warantee-85200/)
Ferocity02 Feb 23, 2003 08:36 PM
I was looking at buying this Camaro today from a local guy. The car is in perfect condition but the passenger side window goes up very very slowly like the motor isn't working right. It has an extended warantee so I was wondering if a problem like this is serious enough to be repaired under the warantee.
Its a 99 Z28 M6 by the way. Thanks
GrdLockV6 Feb 23, 2003 08:48 PM
Most likely if he has an extended warranty. If not, don't let that prevent you from buying a car, GM window motors blow ass and break every 2 weeks anyways :D My '02 T/A only has 6,300 miles on it and both my windows are already movin really slow.
chevy qc Feb 23, 2003 11:09 PM
you've probably owned it a week and a half then. few more days it'll be out. most extended warranties cover the power window motors.
stik6shift98 Feb 23, 2003 11:53 PM
there was a post on the window motor on passnger side moving slower then the other one and i replied that mine go the same way and thats odd.....well now my passenger side window moves slower then a snail:(
mystic98Z Feb 23, 2003 11:57 PM
window
I ran into that same problem where the passenger side window moves very slow...I took it to the dealer and they blamed it on the fact that the camaro has heavy windows.:rolleyes:
stik6shift98 Feb 24, 2003 12:00 AM
how much did it cost to fix.....
