alot of lights came on dash
2001 Camaro z/28 146K Miles
A few days ago my car volt meter would dip into 7 or lower and the CHECK GAUGES light would come on. I would rev the moter and it would go back to a safe reading and light would go off.
Driving to work today I had the Volt meter go to 18, AIR BAG, ABS INOP, and BRAKE Lights come on.
I turned around and went home. I replaced the alternator less than a year ago, and had a similar issue with the volts drop. I took the alternator to be tested and it tested ok.
Do you all think this is just a bad alternator that has an issue when under a load?
Thanks.
Thanks.
1fast Firechicken
04-14-2005 03:07 PM
Black6SpdTA
05-17-2004 08:24 PM
phoenix916
3rd Gen / L98 Engine Tech
08-10-2003 11:16 PM
