CamaroZ28.Com Message Board
-   LS1 Based Engine Tech (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/)
-   -   engine noise? (https://www.camaroz28.com/forums/ls1-based-engine-tech-19/engine-noise-296341/)
nirvana91 Aug 29, 2004 01:43 PM
engine noise?
was listening today and when i got on the car sounded like a ringing or pinging noise. when i got home i let the car idle and when i put my head down by the wheel wells i could hear it real good. its kind of a rough sound a guy told me it was normal for the ls1 because its aluminum and its a noisy engine. i baby it dont hot rod it and as long as ive had it its done it but now its irritating me i use 93 in it. so is there something wrong or does the if you want power the engine is not going to be quiet rule apply? thanks for any help
AL SS590 M6 Aug 30, 2004 12:51 AM
Re: engine noise?
Well right there is your problem ;)
Noise descriptions are almost totally impossible to diagnos on the net. I run the dog snot out of the 00 and always have. Is it noisy? Yep.
If you don't have a clatter that varies with engine speed, a heavy thump, or a constant miss then chances are that the noises you're hearing are normal.
nirvana91 Aug 30, 2004 07:36 AM
Re: engine noise?
thanks man, i saved my a$$ off for the car and it worried me. i dont have none of the sounds you mentioned and it dont use a drop of oil so i guess im just being paranoid. thanks alot :bow:
BirchMan98z Aug 31, 2004 04:54 PM
Re: engine noise?
I think know the sound you're talking about. Kinda like a vibration/tingle? It bugged the hell out of me too so I took it up to the dealer. Turns out it's a wire that bounces against the block and its a washer making the sound. It's totally normal and you get used to it. EVERY LS-1 makes weird sounds. Just wait until your fuel injectors start clicking real loud-- that one always confuses people, they think they have bent rods.
